Results 1 to 7 of 7
Thread: Cracked Sand Filter - Looking For A Replacement
    May 2016
    Toledo, OH
    81
    Morning everyone. Well last night my sand filter gave out and it looks like I am in need of a replacement. I am not sure how old the sand filter is (it came with the house). My pump and motor is about 4 years old (bought new with the house).
    Anyways I was vacuuming the pool last night and backwashing once the pressure increased from about 12psi to 20 or so psi. All of a sudden after two or three backwashes the bottom of the filter split open. I am wondering if I did something wrong, or if this is due to old age, or a combo. I thought the filters were rated for much higher pressure (50psi??).
    Now I am looking for a replacement. I have approximately a 16,000 gallon in ground pool. Currently have an AO Smith SP1605Z1M motor. Unfortunately I did not write down the model number of the actual pump itself.
    I have attached some pictures for your viewing pleasure....any assistance on a replacement filter would be appreciated. I was thinking either a Hayward S180T or S210T
    Thanks all!
    Attachment 48880Attachment 48881Attachment 48882
    Aug 2010
    Dallas, TX
    4,052
    Re: Cracked Sand Filter - Looking For A Replacement
    That's old. My original filter was Pac Fab too. I don't recall when Pentair bought them, but it's been a while.
    You can likely get exactly the same filter today, just with a Pentair name. It makes installation a breeze. That's what I did.
    May 2016
    Toledo, OH
    81
    Thanks. I will check out the local pool store today. We have one local store that sells Pentair. I have a fun holiday weekend ahead of me it looks like
    Aug 2010
    Dallas, TX
    4,052
    Replacing a sand filter is not hard. It took me about two hours.
    May 2016
    Toledo, OH
    81
    Any suggestions on how to transfer the sand? The sand in the cracked filter is less than a week old....
    Aug 2010
    Dallas, TX
    4,052
    Since I was in it, I ditched what I had. It was installed around 1982 and I didn't think to save it. I sawed off the top of the filter with a sawzall and shoveled most of it out.
    But to answer your question, the right way is to use a shop vac, transfer it in batches to a wheelbarrow or whatever, then you can put it back in the new one.
    May 2016
    Toledo, OH
    81
    Great - thanks again for the tip.
