Results 1 to 9 of 9
Thread: Best way to chlorinate pool manually while waiting for SWG parts?
    Ordered a replacement PCB board for my 8 year old AquaRite electronic chlorine generator. Over the next few days, what is the best way to manually keep my pool chlorinated, tablets or liquid shock? It is going to be mid 80s with sun through the weekend.
    IG
    Fiberglass
    35,000 Gal
    Cartridge
    Flow rate on filter coming soon
    Aug 2010
    Dallas, TX
    4,052
    Re: Best way to chlorinate pool manually while waiting for SWG parts?
    Bleach.
    Regular Clorox bleach? Isn't it about 50% less chlorine per gallon compared to the liquid shock?
    IG
    Fiberglass
    35,000 Gal
    Cartridge
    Aug 2010
    Dallas, TX
    4,052
    Clorox is 8.25%. Liquid shock is 10% and in a few cases a little higher. It's your money, spend it wisely.
    When I need it, I just buy plain old store brand stuff, 8.25%. If you can do the math and find it a little cheaper per %, go for it. It's all the same in the end.
    38,271
    Bleach is typically 8.25% while liquid chlorine is 10 or 12.5. You have to compare price and strength. There is a tool posted in a thread that does the calculations.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    A lot of us don't have the option of "liquid shock", the next best thing is the 10% at Walmart for $2.50, and then Great Value and then Clorox, in descending order of economical. If you have access to 12.x% or whatever, awesome!
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Thank you! Will do the math and go with best deal. In any case it sounds like I should avoid buying tablets.
    IG
    Fiberglass
    35,000 Gal
    Cartridge
    In Pittsburgh area, Austin's Pool Tech Shock (12.5% sodium hypochlorite) is available for $3.75/gallon.
    IG
    Fiberglass
    35,000 Gal
    Cartridge
    Aug 2010
    Dallas, TX
    4,052
    Quote Originally Posted by garym View Post
    Unless your CYA is low. It's all about knowing what you are putting in and doing to your pool.
    My SWG manual specifically says "use sodium hypochlorite". Bleach.
