Thread: Heater Damage
    May 2016
    Ottawa/ON
    2
    Heater Damage
    Hi,
    First time poster but have been lurking for a while, very very informative forum.
    I live in Canada and have been paying a company to close my pool every season. I just tried to open up my pool and water was pouring out of my Hayward Millivolt natural gas heater.
    Upon inspecting the heat exchanger, there are four 1 inch cracks in the copper pipes. ISee attached picture (hope it worked) I Googled frozen copper pipes and every picture looks like the crack I have on the heat exchanger. The cracks flare out indicating a crack fracture due to pressure.
    Now of course the pool service company I paid to close the pool to prevent this from happening is claiming it is due to corrosion. PLease let me know if he is full of IT!!!!
    Can anyone share a picture of a leaky pool exchanger due to corrosion? I could not find one to show him.
    Thanks.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: Heater Damage
    The only one's I'm aware of are here: Maintain your chemicals correctly
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: Heater Damage
    I don't have pictures of corrosion leak but split copper like that is from expansion of frozen water most likely. Corrosion would more likely be pin holes in the copper, not a big split like that. Also clearly a sign of bulging as well.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jun 2012
    western NY
    1,560
    Re: Heater Damage
    Nope. That is a classic sign of water freezing in pipes. Also a classic case of the winterizer realizing he messed up and does not want to bear the cost of replacing the heat exchanger. fortunately, if the cracks are all in places like the one shown, any competent radiator repair shop can solder them up.
    Here is a picture of mine when I let my water chemistry get out of hand. Corrosion
    Here is a picture of it after I repaired it.
    Not the best looking repair, but it has held now for 6 years.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    May 2016
    Ottawa/ON
    2
    Re: Heater Damage
    Awesome folks, thanks for the quick replies. This gives me some ammo to deal with the pool guy.
    Thanks.
