Thread: Test Readings
    Jun 2008
    Avon Park, FL
    15
    Test Readings
    Here are my first test readings. I am using the BBB method with bleach. I know it said I need to get the TA between 70 and 90 with the pool calculator and I am working on that now. Should I still sanitize with bleach today since the FC is 4?
    FC 4
    pH 7.6
    TA 110
    CYA 45
    15200 Gallon, Vinyl, Cartridge Filter 100 GPM, SWG
    Re: Test Readings
    Those numbers look good. There isn't any need to lower the TA. You only need to lower TA if you are actually having a problem with PH drifting up too quickly.
    30,431
    Re: Test Readings
    Assuming your water looks great, you'll need to keep your FC up around that range all Summer. The best way to do that is to normally add about 2ppm daily and then adjust accordingly.
    Jun 2008
    Avon Park, FL
    15
    Re: Test Readings
    Does the pool calculator figure the ppm for daily sanitizing with bleach? Also, if my FC is 4 when I checked it this morning should I add bleach or wait to check it again in the morning to see if it drops? Oh yeah, I almost forgot, since I live in FL and we have been getting heavy rains, do I raise FC to shock level or just keep it at normal level?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Test Readings
    With a CYA of 45, your range is about 4 to 6 and NEVER below 4. So if you are at 4 now, you need to add some bleach now aiming just beyond your target for 7 or 8.
    Most of us check our FC levels in the evening and add our maintenance dose (after the sun is off the pool).
    So, add some bleach now and aim for 7 or 8. This evening, recheck and add enough to get to 7 or 8.
    Link in my sig for the CYA/Chlorine Chart.
    You're done SLAMing when:
