Results 1 to 14 of 14
Thread: My DIY pvc waterfall and fountain
    andyrob2215's Avatar
    May 2014
    Portage, Indiana
    127
    Hey guys!
    First off I'd like to say thanks to all the support over the last 2 years I opened my pool this season to a perfectly balanced and clear paradise!
    Anyway, with all the free time I had not worrying about chemicals, I made a new fountain. It's not done yet as I will be adding a diverter channel in the middle, but in case anyone is interested I can answer questions. I can also take more pictures later, this is all I have from the install yesterday.
    You can't see that there is a valve to divert the water to the fountain before the return. From there, there is the waterfall, then the fountain. I had the fountain last year but decided to add the waterfall for this season. I will be adding a channel in the middle of the waterfalls plumbing to be able to have one or the other or both going at the same time. Right now you can either have both or just the waterfall. The idea of this is to be able to "shower" in the pool with warm water from the heater coming out of the waterfall. My family is all cold blooded so they won't go under water most of the time so this way they can get their hair wet and stay warm. any advice for improvement is appreciated or I can answer any questions! Be safe out there.
    21'x52 AGP 11200 Gal
    TFPC Method
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: My DIY pvc waterfall and fountain
    That is a nice looking setup, I may have to modify mine like that
    May 2014
    Portage, Indiana
    127
    Thanks! It's kind of an eyesore when it's off, so I'm going to paint it hopefully that will help
    TFPC Method
    Jul 2013
    Fletcher, OK
    3,353
    dipyourcar.com I used the wheel kit
    May 2014
    Portage, Indiana
    127
    Very nice! I'm definitely doing that
    TFPC Method
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Nice addition to the pool, andyrob! I like the pipe dip too CC.
    Isolated Spa - 345 Gallons
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,522
    I love PVC! Nice tip on the plastidip too, Casey.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Looks good.
    Now get busy and plumb another T and valve in and build a water cannon up there on the edge of the fence.
    As an aside... with two years of troublefree operation and a perfect opening.... no high pressure... Become a supporter
    Oct 2015
    Katy/Texas
    411
    I would like to see a picture of the outlet in the pipe for the waterfall. How long is it and what is the width?
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    May 2014
    Portage, Indiana
    127
    Looks good.
    I'm no expert, but I do have the basics down. I appreciate the thought
    TFPC Method
    May 2014
    Portage, Indiana
    127
    Quote Originally Posted by WASP View Post
    It's about 16" long and I used a Dremel bit to smooth out the bottom edge so the water would pour out smoother. So it don't know the exact inside width. I can get a closer measurement and picture after work
    TFPC Method
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    Looks good! Nice work.
    Above Ground 30' by 54" 22,600
    Hayward S244T Sand Filter w/ 1.5HP Dual Speed Hayward Powerflo Matrix Pump
    TF100 Test Kit
    BBB ALL the way!
    Questions about pool care? Visit Pool School
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    338
    that is awesome looking. is that 1" PVC you used?
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    May 2014
    Portage, Indiana
    127
    Quote Originally Posted by chayne View Post
    1.5 inch, stuff I had left over from the rest of the plumbing. I forgot to get pictures up close I'll get those soon.
    TFPC Method
