Thread: Stupid Question on SWG Generators
    May 2015
    Ten Mile, TN
    74
    I have a two speed pump and normally have it on for only 8 hrs a day at low speed. This is approximately 4 turnovers a day. The high speed I usually use only for vacuuming and sometimes chemical addition. I understand the SWG is only operating when the pump is - so do I buy a Hayward AQR3 and then run my pump continuously ? Or do I get a bigger one (AQR9) and run it part time?
    24' Round 14000 gal AG - installed June 2, 2015
    Saltwater Hayward AquaRite w/TCell - 9
    Waterway 26" sand filter w/ 2HP 2 speed pump
    Taylor K-2006 FAS-DPD Test kit
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Stupid Question on SWG Generators
    Not stupid
    The AQR9 would be twice the size and work less and last longer, it should be a good fit for your pool, you may have to run it 12 hours on low, if you go to the t15 cell it might be enough to do low for the 8 hours you're running the pump now
