Results 1 to 10 of 10
Thread: Ph a little low but.......
    May 2009
    Trenton NJ
    497
    Last year I had stains and did the A Acid treatment and worked pretty well. I use hth metal control ( little cheaper than Mikes magic) and seems to work. My question is I just finished shocking the pool and there are not any stains which is great! But my ph is a little low at 7.0, can I leave it there without any issues?
    I kept it at 7.2-7.4 last year and battled stains all year. Hoping a lower ph might help
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Ph a little low but.......
    7.0 is on the low acidic side, where is your CSI level at in poolmath?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    That is good that you were able to shock with no stains. 7.0 is the lowest it should ever be. And is risky with a heater. 7.2 would make us all feel better about it.
    May 2009
    Trenton NJ
    497
    Ok thanks.......do you think if I aerate it will bring it up enough?
    And what is CSI?
    Aug 2010
    Dallas, TX
    4,052
    Quote Originally Posted by ethany View Post
    And what is CSI?
    Look at Pool Math.
    http://www.troublefreepool.com/calc.html
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    And what is CSI?
    If the TA is relatively high, say 80 or better, then aeration should help. The higher the TA, the faster aeration raises pH.
    CSI is a calculation that tells you whether your water is corrosive to plaster or if it's likely to start forming Calcium scale. Scale starts as some rough blotches and can progress into homegrown sandpaper that will rub the skin right off any body parts that brush against it. Keep CSI below .3 and you'll be okay. Most people never have to worry about it.
    If you post full test results, we can quickly give you a yes or no answer and avoid a lot of ifs.
    DFW, TX
    24,468
    May 2009
    Trenton NJ
    497
    Oh CH.......it's 250
    Fc-2.5
    Ph-7.0
    TA-80
    Cya-20 but yesterday put enough in to increase to 70
    Richard320's Avatar
    Jan 2010
    18,967
    Fc-2.5
    Ph-7.0
    TA-80
    pH should be higher, then. At
    FC 2.5
    pH 7.2
    TA 80
    CH 250
    CYA 70
    Salt I'm guessing 3000 since you have a SWG
    Temperature 80
    CSI is -.7. That's too low for plaster, and might be bad for the gelcoat on your fiberglass pool.
    Raising pH to 7.5 brings it to -.43 which is okay. You want to keep the pH up with a SWG anyway. See Pool School - Water Balance for SWGs
    May 2009
    Trenton NJ
    497
    Thanks all.......my salt is a little high at 3300. I think I'm gonna do borates to keep things stable
