Thread: Help with filter leaks
    Jun 2015
    South Park
    5
    Hooked up a Hayward D.E. filter today that was given to me by a friend. Having issues with leaks it seems where the plastic fitting threads into the pump, as well as where it threads into the filter and at the big coupling that joins the 2 together. Person I got it from said it never leaked before. I removed everything, cleaned them up and put new teflon tape on everything and it's still leaking. Is there a secret on how to get these tight with no leaks or should I use something other than teflon tape? Any help is greatly appreciated.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Help with filter leaks
    South Park? Like with Cartman? LOL!
    More teflon tape. Or pull the teflon tape off and use pipe dope. They do not need to be tight.
    It is good to have a state and a signature with equipment so we can help you better. More here, Pool School - Read This Before You Post
    30,421
    On any fitting larger than 1", I tend to think pipe dope works a better.
    Get ALL that old teflon off and I think you will find the pipe dope will give you a nice seal without having to "crank down" on the fiotting.
