Results 1 to 8 of 8
Thread: Leak in flex pvc pipe
    Apr 2016
    Hilo, HI
    42
    I noticed the drip occurred only when jets were on. After accessing the piping and turning jets on, water sprayed out from the curve in the pipe, spraying to the left. I cannot see the hole as it is around the curve, but drew a red arrow to where I think the water was spraying from (see pic).
    What are my best options for repairing this?
    Before accessing the pipe I ordered some Plast-Aid thinking the leak was at a fitting. The proprietor there explained the differences of the product use on pvc vs. flex pvc (has to do with the butyl layer on the flex pipe). I won't have this item for another 2 weeks, though.
    Is there something I can do now (before guests come over this weekend?) to fix the leak? Thanks!!
    55'x20'x10' 50k gallon free-form gunite with waterfall return, Hayward S310S 30" sand filter, Pentair Superflo VS 1.5 hp pump; TF-100 with SpeedStir
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Leak in flex pvc pipe
    unless it is spraying on electronic parts, fill the tub and have fun
    You can try to wrap a gallon zip lock bag and use zip ties, this will not stop the leak but it will stop the spraying
    I hope this helps
    May 2016
    Hazelwood
    25
    If you have room you could cut and put a 45 on it.
    Apr 2016
    Hilo, HI
    42
    It seems a bit tight to get in there to replace piping. It's between the filter and corner panel, which appears to be nailed on. Don't really want to rip those slats off.
    Maybe for now I'll cover it to stop the spraying and put a tupperware underneath to catch the drips, until the Plast-Aid arrives (assuming it is all that I hear it is).
    I knew I'd find ideas here. Thanks!
    Jul 2013
    Fletcher, OK
    3,353
    that plasti aid is awesome, it does not look pretty when done but it works
    Apr 2016
    Hilo, HI
    42
    Cowboy: I didn't make the fix yet because I assumed your idea of the zip loc was to wrap it around the hose and secure with ties. Unless, you pictured the zip loc serving as a bag to catch the drips. That's not what you thought, was it??
    Jul 2013
    Fletcher, OK
    3,353
    yep just a wrap around the pipe to "slow" the leak down from a spray... the plasti aid is about the only thing I know that should stop the leak..
    Apr 2016
    Hilo, HI
    42
    OK, great. I have my morning's mission!
