Results 1 to 11 of 11
Thread: Suction line question
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    [IMG]
    Do you think it will work to thread a piece in the top part of this pipe and use it as my vacuum line. If i shut off the valves, i should be able to hook up a vacuum line to get better suction for vacuuming. Not to mention the stuff i'm sucking up wont be going through my piping underground. Thoughts?
    40x18 Lazy L Rectangle
    29500gal IG w/ vinyl liner
    HAYWARD S244T 300lb sand filter
    Hayward Super Pump 1 1/2hp
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Suction line question
    It may work but it is going to be a pain to fill it with water or to prime the pump, is it not working through the skimmer?
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    The suction isnt as strong as I would like. Its hard to get sand off the bottom. Maybe if I put a valve on it so i can turn it on when the pump is primed.
    May 2016
    Hazelwood
    25
    Are you making sure to plug all your other suction sides while vacuuming?
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Yes i have 2 skimmers and main drain. I close the other skimmer but leave the drain on. If not i get air bubbles. I'm pretty sure i need a new vacuum hose also
    May 2016
    Hazelwood
    25
    Are you pulling bubbles or is it just not priming all the way? If your pulling bubbles (new hose) like you said if it has holes in it anywhere it's going to slow the Suction from the vacuum heag
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    There are no bubbles in the pump box when not vacuuming. So i figure I have few cracks in the vac hose. The pool used to have 2 returns and a vacuum line. I made the vac line a return to get better circulation in the pool. When that line was there, vacuuming was quick. Now going through the skimmer it takes almost double the time and i have to agitate the sand under the vacuum head to get it picked up. Which of course leaves some in the pool. I'm thinking if I put a designated line back in, I will get the full suction of the pump which = better suction and cleaning.
    May 2016
    Hazelwood
    25
    Shorter the distance from the pump the stronger the suction. If you'd like to add a vacuum side from the female you surely can, just remember you'll have to prime that with a a hose or whatever before starting the pump
    May 2016
    Hazelwood
    25
    Also have you ever tried just running the skimmer? To see if it it has the same results with pulling air?
    May 2016
    Hazelwood
    25
    Quote Originally Posted by Reflectionspoolguy View Post
    Sent from my SM-N910V using Tapatalk
    Without the vacuum hose I mean
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    I guess i can put the vacuum head in front of the return and fill the hose that way. Hmmmm.
    Yes i have run the skimmers alone and no issues
