Results 1 to 10 of 10
Thread: The results are in.....now what?
    Her pool boy's Avatar
    May 2016
    St Catharines, Ontario, Canada
    87
    Our pool was Bromine until we replaced the liner and subsequently the water. I have been circulating water for about 60 hours since the pool filled About to start using the TFPC method as I have been reading this site for several weeks now and am convinced it is the best way to go. the chemistry in my pool has become my new hobby..lol. My Taylor 2006 doesn't arrive until next week so had to us the Pool Store to get accurate readings on my water. They have some good equipment to test the water and provide a computerized printout of the report, with recommended steps to follow to correct the water problems. At this point I have not followed any of their instructions. Here are the results of the water test.
    FC .55 Total C .78. CC .23
    ph 7.7 TA 85 ppm
    Hardness, which I assume is CH 135 ppm
    CYA 9 ppm copper 0 ppm Iron .2 ppm
    presently I am adding Stabilizer to get it to 30 ppm. Store recommends I shock, should I? I am not sure the CC calls for a shock? Any advice?
    SteveS
    16' x 50' - 95K L (25000 gallon) I.G. Vinyl liner 12.5 Liquid Chlorine
    Wicor Pantera P24 Sand Filter Pentair Superflo Variable Speed Pump
    Zodiac 3510WD Robotic Cleaner Raypak R336A Heater. ​Taylor K2006c test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: The results are in.....now what?
    This is a completely fresh fill, correct?
    I'd like to know where the 9 ppm CYA came from. Even if the pipes and filter were full of overstabilized water, that's not enough water to make it even register on the test after it gets diluted with 30000 gallons of fresh. So either their state-of-the-art system is wrong or you've been adding dichlor or trichlor or CYA stabilizer.
    If those readings are correct (And I doubt they are) then all you need is some stabilizer to boost CYA and some bleach. The rest is fine.
    Jun 2014
    15,221
    YEAH!!!!!!!!!! Perfect!
    May 2016
    87
    I have added stabilizer as I knew it was at zero as it was a new fill. I put in 1.75 kg of stabilizer yesterday, tested water today. When I used the Pool Math calculator it said what I added should have raised the CYA to 15, but the reading was 9. My question is, how long does it take for the Stabilzer to fully take effect? I added granular in a sock in the skimmer, and squeezed the socks to help the process along, so all of the stabilizer was out of the socks yesterday. Should I expect the CYA to still raise still?
    SteveS
    May 2016
    87
    Hey tex, they recommended I raise the ph, and add calcium. Total cost for their recommended chemicals was $75. The sad thing is most people would just add it...as told. I was most people....UNTIL NOW. I estimated that I spent $650 on chemicals for my pool annually. I suspect I won't be spending that this year...I won't be fooled again...isn't there a song that suggest that?.lol
    SteveS
    Jun 2014
    15,221
    Good for you Steve! You're absolutely correct on that about the pool store. As for the CYA, once dissolved, it should show most of its CYA in about 24-48 hours. But you can give it 2-3 days to be safe before adding more if you want. You mentioned you were raising the CYA to 15? Is that 15 total, or did you mean increasing by 15 ppm "more"? You'll want a minimum CYA of 30 to get started this season. Just wanted to be sure.
    May 2016
    87
    Is was at 0 so was expecting a reading of 15. I am looking to achieve a minimum of 30 ppm on my total cya so need to raise it another 21 ppm to get there if all my cya was being read In this test. I only have enough to raise it another 15 ppm anyway, so have added it. I won't add anymore until I can test accurately again. So right?
    I meant "sound" right?
    SteveS
    Jun 2014
    15,221
    You got it! After all of that, maybe run another CYA test over the weekend to see how it responded. Have a great evening.
    Richard320's Avatar
    Jan 2010
    19,051
    Okay, that explains things. Maybe their testing isn't all bad.
    $75 on chemicals.... That's what ---about three dollars US? Just teasing.
    Here, I've been waiting for the opportunity to use this.
    May 2016
    87
    Lmao...thanks for that.
    SteveS
