Thread: No free chlorine
    May 2016
    Beaver pa
    1
    No free chlorine
    We opened our pool. We used Algecide and shocked it twice in the last few days but cannot get an free chlorine to register on our test strips. Should I be checking the cya? Thanks for any help.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: No free chlorine
    Welcome to TFP
    Could you please fill out you signature as this will help us Trouble Free Pool
    Guess strips are not helping you, we have a couple test kits that are great and will help you with taking care of your frien/pool
    Check out my links below under test kits, once you order one add 1/2 gallon bleach from walmart a day and brush your pool until your kit arrives...
    we can get you going
    30,415
    Welcome to the forum.
    Algaecide wastes your money. We don't shock a pool. We SLAM a pool. If you decide to read further, you will find the TFP method is all about precision testing, precision dosing and a result of crystal clear water all summer.
    If you take the plunge with us, your eyes will be opened wide and your pool will never look the same.
    Please read "The ABC's of Pool Water Chemistry" up in Pool School
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Welcome to TFP!
    +1 to ordering a TF100 from TFTestkits.net and taking charge of your pool. I've been buying my test kit there for 4 years now and maintaining my pool TFPC style.
    CYA should be 30 and FC should be at target for your CYA, Chlorine CYA Chart
    If there is algae in the pool then you will need to follow this process to kill it, Pool School - SLAM - Shock Level And Maintain
