Results 1 to 9 of 9
Thread: Replace return outlet in Pro Series
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    338
    I would like to replace the return outlet on my Pro Series Pool. I was curious if I could just by an Intex eyeball and make the replacement. I know that my return pipe is 1.5". The return outlet i am looking at says that it is also 1.5". so does it mean i can just take the one in my pool now out and add this one in its place?
    Charles
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Replace return outlet in Pro Series
    Welcome to TFP
    most intex stuff they use different fitting so I am not sure if it will work, you could always return it if it does not work
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    Like cowboy said, you may have to purchase an adapter of some sort or retrofit it. Nothing too overly difficult.
    Above Ground 30' by 54" 22,600
    Hayward S244T Sand Filter w/ 1.5HP Dual Speed Hayward Powerflo Matrix Pump
    TF100 Test Kit
    BBB ALL the way!
    Questions about pool care? Visit Pool School
    chayne's Avatar
    May 2016
    338
    ok i think i am going to go for it. but first things first. i am going to upgrade the pump/filter that came with my pool. i am going to go with the Intex 2500.
    Charles
    Coleman 16'x48"
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    Consider the Intex sand filter combo. Sand filters are easier to maintain but do not filter as fine particles as the average cartridge filter although they will do their job wonderfully. They have a lower HP model for your size pool.
    TF100 Test Kit
    BBB ALL the way!
    chayne's Avatar
    May 2016
    338
    ok thanks for the input. will have to check that one out.
    is this like what you are talking about?
    Amazon.com : Intex Krystal Clear Sand Filter Pump for Above Ground Pools, 3000 GPH Pump Flow Rate, 110-120V with GFCI : Swimming Pool Sand Filters : Patio, Lawn Garden
    Charles
    Coleman 16'x48"
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    There is a lower HP one as well. That one is good also. For your pool, the lower HP one would suffice.
    TF100 Test Kit
    BBB ALL the way!
    chayne's Avatar
    May 2016
    338
    Charles
    Coleman 16'x48"
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    That's the one!
    TF100 Test Kit
    BBB ALL the way!
