Thread: Pool hose
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Pool hose
    Any particular brand? I need a 50ft
    40x18 Lazy L Rectangle
    29500gal IG w/ vinyl liner
    HAYWARD S244T 300lb sand filter
    Hayward Super Pump 1 1/2hp
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pool hose
    I used a modified hose that is much thicker and way better that a regular pool hose
    it is 1.5 inch and I cut 1 foot off the end and connected it up Amazon.com: Apache 98138045 2 Scientific
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Re: Pool hose
    I need that end to put into my skimmer. I guess i could cut the plumbing and put in a direct feed into the suction side
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Re: Pool hose
    Do you think i can screw in an attachment in that cap in the top and use that to vacuum? Im wondering if i would get better suction and i also won't have to worry about vacuuming through my skimmer. I really dont think i get adequate suction since i made the one line a return instead of vacuum line.
