Results 1 to 10 of 10
Thread: Adding sheet metal around my pro series pool
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    345
    I was sitting in the pool last night and I thought, would it be possible to add a thin sheet metal around the outside of the posts. I thought that it might add some strength to my pool so that maybe it would not move so much. I dont know thought. I was thinking that maybe going from ground level to maybe the bottom of the connectors. What do you all think?
    Charles
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    Re: Adding sheet metal around my pro series pool
    I haven't personally seen this before. Your main concern is wall integrity correct? Also can you clarify what you mean by "move too much"?
    Above Ground 30' by 54" 22,600
    Hayward S244T Sand Filter w/ 1.5HP Dual Speed Hayward Powerflo Matrix Pump
    TF100 Test Kit
    BBB ALL the way!
    Questions about pool care? Visit Pool School
    chayne's Avatar
    May 2016
    345
    yes that is what i was looking for more wall integrity. by moving too much what i was referring to was that when the kid jumps in, the walls sway a little bit. it makes me kinda nervous. i have taken my hands and placed them on top rail and shook pool pretty good and nothing happens other than it just sways. i just thought that maybe if i put the sheet metal around the outside of the pool that it might keep that swaying down. i have a buddy that owns a sheet metal shop and he would give it to me for a really good price. it would be one solid piece screwed to the poles with self tapping screws that would not go all the way through to the liner.
    Charles
    Coleman 16'x48"
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    If you were to do this you would have to ensure the sharp edges would not puncture the liner. Also would you just leave the pool up year round? Is that what you plan to do? I haven't heard of many stories of steel framed pools collapsing. As long as you are level you should be fine.
    TF100 Test Kit
    BBB ALL the way!
    chayne's Avatar
    May 2016
    345
    no was not planning on keeping up all year this year, but for sure next year. i will be building a partial deck on one end of the pool. yes, that is why i was going to place the metal on the outside of poles away from the liner. would probably even have my buddy crimp the top edge of the metal so that there would be no sharp edges to cut hands or anything else.
    Charles
    Coleman 16'x48"
    Apr 2013
    Sacramento, CA
    2,769
    Your pool probably already has a top cord. Give us a picture. Even something as simple as two wraps of "truckers rope" would stiffen it up a lot. Maybe too much. Some engineer with colored pencils and a slide rule figured out the forces on your pool. It may not work as well stiffer.
    mbuice's Avatar
    Jul 2014
    Denton, TX
    95
    Howdy from Denton!
    I would love to see some before pictures, I think this is an interesting idea.
    18 X 34 AGP 7ft deep end, 22,300 gallons. 250lb sand filter, 2 speed 1.5 hp pump. TF-100 Test Kit.
    chayne's Avatar
    May 2016
    345
    Howdy to you down there in Denton. I will get some pics on here tomorrow. No my pool does not have a top cord. What do you mean by top cord. I only have the webbing around the bottom. You mentioned something about truckers rope. Don't think I have ever heard of that. Don't guess you mean ratcheting straps?
    Charles
    Coleman 16'x48"
    Jul 2014
    Oakbank, Canada
    389
    Ratcheting straps would be it.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    chayne's Avatar
    May 2016
    345
    ok, so i went and got a ratchet strap. i just have one question: how far down from the top do you all think i ought to run these straps?
    Charles
    Coleman 16'x48"
