Thread: White foam on pool
    May 2016
    Yardley
    1
    White foam on pool
    I have had the pool open for almost two weeks opened swampy green, vacummed to waste and added bleach pool is clear with a white foam film on top. i have been running the filter 24/7
    bought a test kit. FC - .6 CC 1 Bromines 1.3 pH 7.2 added 1 drop to get the acid level up to 7.4
    HELP
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: White foam on pool
    Welcome to TFP
    what test kit did you get?
    Could you post all your results like below
    FC
    pH 7.2 perfect
    TA
    CH
    CYA
    we will get you going
