Results 1 to 15 of 15
Thread: 1 in 5 Americans admits peeing in the pool
    Jul 2007
    Sahuarita, AZ
    278
    http://www.livescience.com/health/09...l-hygiene.html
    Have you done it? I think the percentage is actually much higher though.
    My Pool:
    12K gal IG gunite with 7' raised spa, gunite waterfall, PebbleTec Caribbean Blue finish, solar heating & in-floor cleaning system
    Equipment: Sta-Rite 300' Cartridge Filter, Intellichlor IC20 SWCG, Sta-Rite 400k BTU heater, Intelliflow 4x160 main pump & Sta-Rite 3/4 hp waterfall pump, EasyTouch controlls w/ wireless controller, TF-100 Test Kit w/ salt test.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: 1 in 5 Americans admits peeing in the pool
    I'm pretty sure that folks are divided into two groups - those that have peed in a pool, and those that are liars.
    But I've never done it myself.
    Jul 2007
    Sahuarita, AZ
    278
    What's the big deal anyway? Urine is sterile right? Yeah, it'll chew through the chlorine a little faster, but you can't catch anything from a little peepee can you?
    My Pool:
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by EskimoPie
    Not if you have a bladder infection.
    --paulr
    BBB "Intermediate Swimmer"
    Mar 2007
    San Rafael, CA USA
    12,082
    As noted in this thread my wife is a proud member of that 1 in 5.
    As described in section 4.3 in this document, urine is composed mostly of urea and then some ammonia and some other nitrogenous compounds. The 12,220 ppm-N in urine takes over 93,000 ppm FC in that same urine volume to get rid of it. So adding 1 cup of urine in 15,000 gallons would consume around 0.4 ppm FC from the entire pool volume.
    It is rather innocuous except as noted in terms of possible bacteria, but they should get killed quickly after the chlorine reacts with the ammonia (urea is slower to react with chlorine). If you have many children all peeing in the pool, then one should have a much higher chlorine level to take care of this extra demand.
    Richard
    Henry Porter's Avatar
    Nov 2008
    Sweden
    604
    Quote Originally Posted by Ohm_Boy
    I have NEVER peed in a pool but I admitt that I do it in the ocean from time to time.
    Inground concrete pool 14600 gallons,Pentair Whisperflo 3/4HP WFE-3, Hayward swimclear 420sq ft
    Zodiac LM3-24 SWG, Dolphin Diagnostic poolrobot, Heatpump Gullberg&Jansson 13,8KW, TF testkit.
    Seen a shooting star tonight And I thought of you You were trying to break into another world A world I never knew
    I always kind of wondered If you ever made it through Seen a shooting star tonight And I thought of you
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Rule #11 in the Forum Rules and Etiquette state that we do not discuss peeing in the pool.
    It just makes folks uncomfortable.
    Butterfly's Avatar
    South Carolina
    10,045
    Those were good articles
    Chem Geek's (Richard) link really got the ball rolling on this a while back. And remember, lots of us drink lots and lots of water
    You're done SLAMing when:
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Personally, I think it's always a good thing to occasionally get out of a pool just to go to the bathroom, whether one needs to or not...
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Pisces's Avatar
    Jun 2008
    League City, Texas
    273
    Dying!! That was hilarious Ohmboy!
    7,000 gal. IG gunite, SWG, PebbleSheen interior finish-Aqua Blue, 8' vanishing edge raised 16-jet overspill spa, 2 12" waterfalls, tan shelf with bubbler.
    Pentair equipment: Easy Touch 8, Intellichlor IC-40, Intelliflo VF 3050, 2.5 hp Whisperflo spa pump, 1 hp Whisperflo water feature pump, Quad 100 DE filter, Master Temp 400 heater, Legend Platinum Cleaner (3/4 hp pump). Autofill, TF-100 Test Kit w/salt and borate strips.
    Pisces Pool Build
    Butterfly's Avatar
    South Carolina
    10,045
    11,969
    OMG that was too funny....rollin on the floor funny.
    coastal's Avatar
    Apr 2009
    Naples Florida
    87
    Quote Originally Posted by chem geek
    Richard
    Well now we know what to do if the pool gets over chlorinated
    Aprox 30' X 18' Free Form Shot - Crete In Ground
    Pool, Spa, Sunshelf, 8800 Gallons
    Pentair Intelliflo Vairable Speed Pump
    Pentair 150 Sq Ft Cartridge Filter
    Pentair Ultra Temp Heater
    Mar 2007
    Coastalish 'down easter'
    4,160
    OK - I guess now it's 2 in 5, but I only do it to warm the water...
    Luv& Luk
    -Ted
