Thread: Clorox SPA Ph Down
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    156
    Clorox SPA Ph Down
    Can I use my Ph Down from my HT in my pool? It says it's Sodium Bisulfate or do I need to make a Lowe's run... It's not high (7.8) but I want to stay ahead of it and not play catch up...
    TIA!
    Intex 20x52 above ground pool-
    8632 gallons
    1 man 4 woman Bullfrog Hot Tub
    http://www.flickr.com/photos/pitguy3/se ... 763801706/
    ROLL TIDE!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Clorox SPA Ph Down
    It will work fine until you get some MA
    "Dry acid is best added by pre-dissolving it in a bucket of water and then pouring that slowly in front of a return." from Pool School - Recommended Pool Chemicals
