Results 1 to 7 of 7
Thread: texted my pool guy to price swg
    May 2016
    Malin
    15
    he asked me what a swg was....i told him...no answer...guess he doesn't install them...researching to diy but out heater sits about 6 inches away from outer wall...would we have to drill through it to install? any ideas?7093d307-5b71-4739-ad2d-347625236e78.jpg
    Norma V from Fallon,NV
    20000 gal fiberglass ig pool ..tf-100 on well water..sta-rite sys 3 and intellipro variable speed pump, sand filter, kreepy krauly
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    Re: texted my pool guy to price swg
    Can you take a picture of your entire equipment pad?
    There are many SWGs that can be owner installed if you're the least bit handy. You just have to have the right place to put it.
    May 2016
    Malin
    15
    my husband is quite handy and i am a good supervisor.....the sun didn't allow a very good pic but here it is..top leans back when heater is on...thank you! i can prob lift lid and take better pic if you need...
    May 2016
    Malin
    15
    better pic
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    You should have room in there to install a SWG, here is a chart of the different one, I really like my curcupool but any of them will work great, some better than others
    Full Market Comparison of Salt Water Chlorine Generators for Swimming Pools
    The SJ40 would work good for your size pool but the SJ55 would last a little longer, add the 1 $ upgrade
    CircuPool® SJ-20 Salt Pool System
    Jun 2013
    Freehold NJ
    133
    man, I dontlike the heater covered like that
    38,000 gallon vinyl liner, True "L", Sand Filter, Hayward Heater, Diving Board
    May 2016
    Malin
    15
    joe, i lift the top cover when it is in use..
    thank you, casey! i will certainly look into them!
