Thread: Waterline ring...
    Jul 2015
    Port Neches, TX
    53
    Waterline ring...
    Hi All,
    We had our 25 year old FG pool repainted in March and there's already a heavy black ring at the waterline. I'm the only swimmer and have been in maybe a dozen times since early May. I found that it comes off pretty easily with Lava bar soap in a plastic scrub pad, but what would be causing this? Water balance is perfect. We live in a heavy (air) pollution area, could that be the cause? Is there anything I can add to the water to prevent it? Seems like it worsens after a rain...
    Russ
    15x30 18k gallon fiberglass "Lazy 8" inground pool, Aquarite 40k salt generator, 1 HP pump, Hayward DE filter, Barracuda G3 (side port) cleaner.
    Jun 2014
    15,023
    Re: Waterline ring...
    Hi Russ. Sounds like a scum line. Don't worry, it's not a reflection of you as the main swimmer. I get it from time to time even with no swimming - usually against the same corner in my pool. The water just collects oils and bacteria that collects in some areas and is sort of gummy in texture. You did right to clean the area. You might also see it in your skimmer at times. There are some products on the market (i.e. Scum ball) that have been known to help with that issue. Just one of those things we see from time to time.
    Jul 2015
    Port Neches, TX
    53
    Thanks, Pat!
    I looked at them on Amazon, you just dump one in and let it float around? Is one good or a couple better?
    Russ
    Jun 2014
    15,023
    That's about it Russ. I've actually never used one yet. On the rare occasion I get a scum line, I just clean it off and I usually don't see it again but maybe once or twice a year. Weird.
    Jul 2015
    Port Neches, TX
    53
    I've had one of these in the pool now for about 10 days and no more ring! This after a couple really heavy rains, heavy enough to require pumping water out a twice. So far, the scumball still looks and feels "normal", as in no obvious buildup of crud...
    Russ
    Jun 2014
    15,023
    Nice!
