Whew, I'm glad your pump is okay!
I noticed that you said your FC dropped from 20 to 5 on Sunday, but your CYA is still 0. With no CYA your SLAM FC is 10, you really shouldn't intentionally increase FC more than a point or two above 10. CYA buffers FC, this makes it less harsh on your liner and protects it from the sun. Without CYA you are probably losing a lot of FC to the sun each day.
If you haven't added any CYA yet you need to do that now with a target of 30. Put the granules in a sock and hang it in front of a return or put the sock in your skimmer. You can squeeze the sock every now and then to help it dissolve faster. Once the CYA is added, your new SLAM FC will be 12.
