Results 1 to 7 of 7
Thread: Sand Filter, Intex 4,500 gal pool
    May 2016
    Chicago, IL
    23
    Hi All,
    As mentioned, we just purchased the Intex 18' x 9' x 52" Rectangular Ultra Frame Pool. With a capacity of 4,500 gallons I question whether the included sand filter is sufficient at 1200/gph. Any thoughts on this? Should I be looking at a filtering system >1200/gph?
    Again, thanks.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Sand Filter, Intex 4,500 gal pool
    it should work just fine, you can go to a bigger pump/filter it will allow more time between backwashes
    May 2016
    Chicago, IL
    23
    Quote Originally Posted by cowboycasey View Post
    Many thanks, really appreciate the input. Picking up the pool tonight. What is the frequency of backwasing dependent upon? It's purpose?
    Again, thanks!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Quote Originally Posted by lgldsr View Post
    Again, thanks!
    Frequency depends on how much dirt gets in the pool. Rather than type a whole bunch, I'll just refer you to Deep Cleaning a Sand Filter because it has some good pictures that show the innards of a sand filter and some flow diagrams down where it says Sand Filtration 101. It explains it better.
    May 2016
    Chicago, IL
    23
    Thanks Richard!I also wanted to ask since this is my first time with a sand filter. If I understand correctly I still have to shock the pool water as I normally would with a conventional filter (cartridge) and everything else being equal? In other words, a sand filter doesn't require any additional chemicals in lesser or greater amounts than would a cartridge filter?
    Richard320's Avatar
    Jan 2010
    19,046
    Nope.
    May 2016
    Chicago, IL
    23
    Nope.
    Again, thank you. You've been extremely helpful!
