Thread: Green Algae Pool
    May 2016
    Cincinnati/OH
    1
    Green Algae Pool
    New to pools... I used the pool the summer of 2015 without any problems. Decided to leave it up, filled and uncovered over a mild winter and now it's green. Trying to figure out if it's best to drain and start over or if it's worth fixing using BBB instead of high priced chemicals.
    hth 6-way liquid drops test:
    Total Chlorine .5
    Total Bromine 1
    Ph 6.8
    CYA 40
    TA 0
    Total Hardness 110
    Intex 15'x42" AG Metal Frame Pool, 3,110gal, Krystal Clear Catridge Filter Pump, model 637R
    Jun 2014
    15,243
    Re: Green Algae Pool
    Hello and welcome to TFP! At just over 3K gallons, your pool is right at what we call a "seasonal" pool. Might just be easier to drain it, or most of it anyways. But the products we use to clear a green pool from algae are basically regular liquid bleach. But you do need the right test kit (i.e TF-100 link below). So it's really up to you. If you decide to invest in the TF-100 (great value by the way) and decide to clear the algae by using the TFP "SLAM" technique (link below), we'll be happy to assist you. Let us know how you would like to proceed and we'll be glad to help. Great to have you with us.
