Results 1 to 13 of 13
Thread: Intex inlet leaks
    May 2014
    Corona, CA
    21
    Intex inlet leaks
    So I bought all new inlet and outlets and new valves and both leak from the threads. Has this happen to anyone else? I have tightened as much as I can because I don't want to over tighten and bust the threads and have a even bigger problem. Right now i just have a cup under catching the water but that just isn't ok with me for new parts. I installed these the same way last year with no problems. Only thing I can think of is I got a bad batch.
    Intex 14'x42"
    Intex 14" 2800gal sand filter pump
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    Re: Intex inlet leaks
    Have you tried using plumbing tape? That should solve the problem.
    Above Ground 30' by 54" 22,600
    Hayward S244T Sand Filter w/ 1.5HP Dual Speed Hayward Powerflo Matrix Pump
    TF100 Test Kit
    BBB ALL the way!
    Questions about pool care? Visit Pool School
    May 2014
    Corona, CA
    21
    Quote Originally Posted by Blake1989 View Post
    Thanks you for your input and not to sound like a jerk, but I am aware that would fix the problem but I'm not draining my pool for such a small leak and it also shouldn't be leaking. If I would have known I would have taped the the threads as I do with any plumbing. Just wondering if Im the only one.
    Im hoping with how much minerals we have in the water that it might seal itself but that's wishful thinking I'm sure.
    Intex 14'x42"
    AmyMrsR's Avatar
    May 2015
    Spotsylvania, Virginia
    113
    sounds crazy but I had a new return that didnt fit my old Intex plugs. So I could work on the threads, I rubberbanded a sandwich baggie nice and tight around the return on the inside of the pool. I dont know what size inlets you have but on the smaller Intex inlets you have that black plug you can pop on at the inside once you remove the screen. That stops all the water to fix the threads. No, it shouldnt be doing it but if Intex wants you to send back the defective parts, you'll have to do something while everything is shipping or if you decide to try and fix it. either way.
    Just a thought...it also could have gotten cross threaded when you put it on.
    18'x48" Intex 14" Intex sand filter est. 7100 gallons- Winterized 2015-16 with success! added Skimmer 2016.
    May 2014
    Corona, CA
    21
    I could never cross thread haha! It possible but not likely. But like I said its a small leak but its just annoying to me that a new part does this. When the summer is over I will drain it below the inlet ans fix it.
    Intex 14'x42"
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    Can you tell if the water is coming from the valve side or the outlet side? Just thinking out loud, if the leak was on the outlet side, maybe the rubber gasket is not sealed well. If from the valve side, then all the above mentioned thread suggestions apply. I don't remember, is there an o ring or a gasket on the valve where it screws onto the outlet? If so maybe a little silicone grease would help?
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
    Mar 2016
    Wantagh, NY
    31
    I believe there is supposed to be a l-shaped gasket where the valve fitting screws into the outlet.
    Jul 2014
    Oakbank, Canada
    389
    It is the rubber gasket on the inside that is leaking, been there - done it. Only thing to do is drain, take it apart, clean and put a very little film of Vaseline on the rubber gasket, the reassemble. Just needs a little help in sealing sometimes.
    I have used Vaseline on these gaskets for the last 4 years with no issues.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Jun 2012
    Central Alabama
    55
    I had to replace the step down or L shaped gasket on the plunger valve a few years ago in the middle of summer. I just got my wife to hold a bowl over the intake and I unscrewed and replace the gasket on the outside. Make sure you close the other valve before hand!! We only lost what water was in the hose and with the wife holding the bowl it kind of created a suction against the intake sealing any more water from leaking out.
    Intex Ultra 16x48
    Intex 2650 Sand Filter
    Installed June 2, 2012
    What Darrel B said. Vaseline the threads and gaskets and you should be AOK.
    May 2014
    Corona, CA
    21
    Quote Originally Posted by RollTideRoll View Post
    Might have to try that.
    Intex 14'x42"
    philc's Avatar
    Jul 2015
    190
    Yep replace and/or lube that gasket. I also have had a "helper" hold a bowl over the outlet to prevent losing much water.
    Jul 2014
    Oakbank, Canada
    389
    One option you also have is to put a secondary gasket between the large flange nut and the liner. Have someone hold a large bowl over the housing on the inside, loosen off the nut and install another gasket. Might be able to find something at you rlocal big box, or just make one from a piece of rubber.
