Thread: grrrrrr
    May 2016
    Maumee
    3
    grrrrrr
    I am very new to being a pool owner... I have read pool school and have read alot of the posts asking similar questions. I have set up our pool for the summer and filled it with city water. I added 175LBS of salt, one bag of shock, and 1/2 Gallon of 35% CYA. I have not turned on the SWG yet because the FC was high. It finally is coming down so I can turn that on but my PH is above an 8.2. Do I need to add something to lower the PH? I plan to take my water to the pool store to be tested tonight so I will have more numbers then for you but I dont just want to get what they tell me because they are often wrong. Thanks so so much.....
    Robin
    18' X 52" round intex AGP
    Intex SWG
    21" Sand filter (no brand) 1.5HP pump only one speed
    triptyx's Avatar
    Apr 2016
    1,438
    Re: grrrrrr
    Yes on the Ph. You'll want to get Muriatic Acid to bring that down. Use PoolMath to figure out how much you'll need. I called around and was able to get it for around $7.50 a gallon (20baum) here.
    Please consider investing in a proper test kit from TFTestkits.net - either a K-2006 or a TF-100 (the TF-100 is a better value). You'll save yourself a lot of time and wrong readings - the pool stores can give you 5 different answers on the same sample of water.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    May 2016
    Maumee
    3
    Re: grrrrrr
    Thanks so much....
    Intex SWG
