Thread: Liner Rails
    Feb 2014
    Petal Mississippi
    2
    Liner Rails
    I would like to repaint my in ground vinyl liner pool rail. I s there a special paint and if so where to find it. Thanks, Vince
    :cool:[Since 2006] 25000 gal, rectangular, vinyl [Tara Manufacturing Inc], in ground, Aqua Rite [AL-0] chlorine generation [software RL.158] [cell T15]. Hayward Super Pump 2, 1hp [SP3007X10AZ]. Polaris 280, 1hp Hayward booster pump [#PB4-60]. Amerlite underwater light [Pentair]. Reem 266000 BTU Propane heater. Solar cover [Ray Max Gold Series]. Intermatic 220v timer [T104P3]. Hayward Pro Series sand filter [S-224T] 300LBS.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Liner Rails
    If your rail is metal, I would rough it up with sandpaper and/or steel wool and use a metal primer paint and a second coat of enamel. There are two-part marine polyurethane paints, but they are expensive and probably over kill.
    Isolated Spa - 345 Gallons
    Re: Liner Rails
    Hi vmwonders. You probably dealt with this already, but the product you are (where) looking for is "Coping Paint". It is for aluminum coping.
    Making Liners Since 1997
    Pool Liner Factory Outlet
