Results 1 to 8 of 8
Thread: Easy way to stock up on bleach
    Dec 2011
    Prosper, Texas
    124
    For my last few bleach runs I have used Walmart's online pickup. You order online and schedule a pickup time. Show up and they load the bleach for you. The great value 8.25% is only $2.94 for 121 oz bottle.
    If you haven't tried it here is a link to get started.
    Walmart Grocery - Online Grocery Pickup Delivery
    21,000 gallon pool w/spa, Pebble Sheen, Hayward EcoStar variable speed filter pump, Hayward DE6020 Filter, Hayward 400FDN Heater, Stenner pump with 15 gallon tank, Clear O3 ozone system, Hayward Goldline PS-8 controller, Hayward 6060 cleaner pump, Polaris 280 cleaner, Hayward EcoStar variable speed water feature pump.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Easy way to stock up on bleach
    Nice find
    Dec 2012
    Manassas Park, VA
    205
    Walmart now carries liquid chlorine in the pool section 10% for $2.50 a gallon. I would check to see if your local Walmart carries it.
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    I just looked at some of that 10% and the date code is already 3 months old. 2 endcaps worth.
    May 2016
    MD
    195
    how long does bleach last? I didn't really look at the codes... hmmm. will double check. I have to go back to walmart tomorrow anyways
    IG, 25k gallons, 20x40 ft, Plaster, Pentair sand filter, variable speed pump, have a well, TF-100 test kit, Speed Stir
    Mark R's Avatar
    Nov 2013
    Desert Southwest, USA
    166
    I dragged myself into Walmart today to by some stabilizer and saw 10% liquid chlorine for 2.97 per gallon.
    12k gal Gunite/Hayward filter C5520BH with quad 33 inch filters. 2.5 hp motor. Pool is on south side, so full sun light. Spill over spa.
    Laar's heater LT250-Low NOx Gas Fired for pool/spa 250,000 BTU. Roof mount 6 panel solar system installed east/south. TF-100 test kit. May-September 100+ degrees out side.
    Jul 2011
    Mesa Arizona
    190
    I'm in the Phoenix Arizona area. I was in Walmart just yesterday. Yup. $2.50 per gallon. Works for me.
    So how does a person read the code to see when it was made???????
    Mesa Arizona. Old school 26,000 gallon in ground plaster pool with sand filter built in 1984.
    Jul 2013
    Fletcher, OK
    3,353
    Quote Originally Posted by Mesamav View Post
