Results 1 to 7 of 7
Thread: Starting from Scratch, Drained and starting over
    aridpaul's Avatar
    Oct 2007
    Phoenix, AZ
    14
    Drained and powerwashed my pool yesterday.
    Filled my pool last night.
    Turned my pump on this morning. Let it run an hour before doing water test.
    Taylor 2006 kit and an Aquacheck phosphate test kit.
    Before drain numbers
    FC 0
    pH 7.4
    TA 140
    CH 750
    CYA 220
    Phos > 1000
    After Drain and Fill
    FC 1
    pH 7.9
    TA 140
    CH 250
    CYA 0
    Phos <200
    Where do I go from here?
    We drained the pool as lower as it could go without damaging the pump.
    I know I need to add CYA I don't have a problem buying liquid to get it up fast enough to hold Chlorine. Is there any difference of brand?
    We are giving up on tabs and switching to BBB method.
    We have Calcium build up on tile and would like to lower the ph to 7.2 to help with that.
    We took a class on swimming pool construction many years ago and was told not put more than 2 cups of Muriatic Acid a day.
    We had this pool built 12 years ago.
    Thoughts? Order of operation and adding chemicals into the pool?
    Paul
    18,000 in-ground pool, Pebble Fina Finish, 2hp Pentair pump, Hayward 311sx sand filter. KT 2006 Test kit Tabs/bleach
    Flbeachluvr's Avatar
    Mar 2016
    Port Orange, FL
    363
    Re: Starting from Scratch, Drained and starting over
    Quote Originally Posted by aridpaul View Post
    I'm sure an expert will chime in soon but almost daily I need to add around 3 cups of MA to my pool due to the new plaster.
    Pool completed 3/21/2016
    8800 gallons, plaster 14' x 24', 3/4 hp Hayward pump, Hayward cartridge filter, Blue Essence T-5 SWG, Kreepy Krauly Kruiser, Taylor K-2006 test kit with Speedstir, Taylor K-1766 salt test and 250 sq. ft. of Heliocol solar panels with Pentair Solartouch control system
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Paul,
    Nice job, How does your water look?
    take your CYA to 30 to start out, you may need to take it to 40 or 50 because of your location but you can start at 30
    If cloudy you may want to SLAM, let us know
    I have poured a whole gallon of MA in at once, as long as your pump is running on high and you pour in front of the return and brush afterwards you will be fine
    Bring your PH to 7.2 using poolmath above
    Aug 2010
    Dallas, TX
    4,052
    How can they tell you how much MA to add without knowing the pool size? I add a gallon at a time to mine sometimes.
    You can ignore phosphate readings.
    aridpaul's Avatar
    Oct 2007
    Phoenix, AZ
    14
    Pool is looking good right now! Still haven't added anything to it.
    30,431
    Welcome to the forum.
    Why not? Start to get your levels in order. We normally take pH first, then CYA and then FC.
    TA and CH can wait for fine tuning later.
    PoolMath tells you exactly how to dose your pool to achieve desired results. I would bring it up top speed before algae starts to form.
    aridpaul's Avatar
    Oct 2007
    Phoenix, AZ
    14
    All I have on hand right now are trichlor tabs, liquid bleach, and acid. Waiting for my car to get back so I can get to the store. Need to get the CYA to add to it. Planning on purchasing liquid. How long should I wait to test levels? after I add it how long until I add chlorine?
    Thanks for your help.
