Thread: Best way to salvage tears in pool liner
    May 2016
    Washington Twp, MI
    2
    Hi All-
    I'm new to the site, and hoping for some help. My pool is opened, and although we had a few minor tears last year in the liner, they are getting worse this year. However, I have already invested in pool chemicals (before I found this site), water, etc, and don't want to pay for a new liner until the end of the season. For reference, the liner is at the end of its life expectancy (about 14 years), pool came with the house we bought last year, and I am trying to get through the rest of this season (September) before replacing it. Should I continue with regular vinyl patching and cross my fingers? Is there better patching or glue out there rather than what the pool store has? Thank you in advance for any assistance.
    InGround Pool, Vinyl Liner, 30K gallons, Pentair FNS Plus DE Filter, Hayward 200 In Line Chlorinator, Well Water
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Best way to salvage tears in pool liner
    Welcome to TFP
    this stuff is awesome, I have used it but not in the pool, people have used it in pools and said it worked great.. Not sure what you are using now..
    Amazon.com: Tear-Aid Repair Type B Vinyl Kit: Sports Outdoors
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    If you arent already doing it.. multi-patch it.
    Put a normal size patch over the hole.
    then cut another that is 2 inches larger on all sides than the first and patch over top of the first patch.
    A 3rd on top wont hurt.
    Divin Dave,
