Thread: Pool water behind liner.
    May 2016
    Frankfort
    7
    I'm new to TFP, but man do I wish I would have found this site 3 years ago when I bought this house. After 3 days of running my pump this year and starting the SLAM process I suddenly started to lose 3-4" in a 24 hour period and to make matters worse the liner floated and came out of the track. Water level behind the liner is exactly the same as pool level no matter where I fill level to. I followed advice and filled level back high turned the pump off and the leaking has seemed to stop but it's hard to tell if the the liner is settling. Mind you we have had 0 rain this week so I don't see how it could be ground water. I believe one of my returns is forcing water behind the liner so I'm looking at advice on how to attack this problem and return my liner to usable form.
    My current plan of attack is to suck the water out using either a portable pump or my pools vacuum hose then re-attach the liner make a temporary return back to my pool so I can continue to SLAM while finding and fixing the leak (if level stops dropping with the temporary return).
    In-ground vinyl with liner.
    Approx 30,000 gallons
    Came with house purchased in 2013
    Built in 1998 I believe.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Pool water behind liner.
    Sounds like you have a reasonable plan. That is quite a bit of water behind the liner. If you can figure out a way, close of flow to the return you suspect may be pushing water behind the liner.
    Isolated Spa - 345 Gallons
    May 2016
    Frankfort
    7
    To update I allowed the water to suck out from behind the liner for about 3 hours, I didn't want it to run over night and risk damaging the pump if it lost suction. https://youtu.be/hXL-inKVHgI That link is a video of the set up if anyone is interested. So for the update allowed the pool to circulate through my temporary dishcharge line while taking suction from the bottom drain all night and still lost about 1" but there is a 5dps leak on my temporary discharge line. Some water returned to behind the liner but that was expected if there is a leak. If anyone has any further guidance on where I should start looking for the leak it would be greatly appreciated.
    Thanks
