Results 1 to 7 of 7
Thread: Considering Hot Tub
    Considering Hot Tub
    So I've been following the BBB method of maintaining my pool for a couple of years now and appear to have it down good. Now I'm considering getting a Hot tub but am confused with all the discussions on should i use Chlorine or Salt Water or Bromine.
    Do i get an ozonator
    Are they more difficult to maintain?
    I've heard Chlorine does not work as good due to the high temps and it gases off more and causes more skin irritation.
    Comments or suggestions as the Trouble Free recommended way to go?
    Located in Ottawa, Ontario Canada
    23K Gal, AG, Cart filter, 1.5hp 2speed hay PowerFlo Matrix, Install Sum'13, Aquatrol SWG, Solarbear panels, kreepy Krauly E-Z Vac, TF-100
    Artesian ~500gal Grand Gayman Island Spa
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Considering Hot Tub
    You can use either. Ozonators can be helpful for breaking down waste products in heavily or frequently used spas. Chlorine and bromine are just as effective when maintained properly. I will say that my spa is more work than my pool to maintain because of the size, average temperature and relative bather waste load when it is used. I am strongly considering adding an in-spa SWG system to maintain the spa more easily.
    Isolated Spa - 345 Gallons
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    I love my hot tub and use it every day from sep to apr.. I went through using bromine (could never get it to work), then to chlorine (worked great but daily additions needed and I am not good at that) and then went SWG because, well, it works and adds daily for me
    Because I know what its at once the water is balanced I test 1 to 2 times a week, I hit the superchlor on the SWG after I get out and it kicks it up to 24 minutes chlorine instead of the 12 minutes every 3 hours
    Once a month I bring my water to SLAM level and let drift down over a couple days just to burn off anything.. I still have the ozanator on but once it dies I will unplug it..
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    250
    I used Bromine, and had the floater with bromine tablets wide open all the time..Water stayed clear and clean from November thru last week when I drained it...Yes I shocked once a week..
    24x16 doughboy Summerville..22" Waterway "sand" 1.5 HP 2sp motor..Misty Falls liner, and wedding cake stairs..
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    We love our hot tub on bleach. We've had it for 3+ years and use it a few times a week. I am also considering SWG for my tub, but bleach is so easy I'm not all that motivated.
    Here is how we maintain it, How do I use Chlorine in my Spa (or pool)?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I too have an SWG on my tub, it is a drop in Saltron Mini
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    I'd go SWG if i had the choice when we bought ours. So that's my vote.
