Thread: Question on mustard algea
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    I know when you brush it away, it will poof up in a small cloud, but will algea allow you sweep it really slow into a pile? Or should it fall apart regardless? My readings are still perfect, so wondering if it might just be pollen...
    24x16 doughboy Summerville..22" Waterway "sand" 1.5 HP 2sp motor..Misty Falls liner, and wedding cake stairs..
    30,421
    Re: Question on mustard algea
    No, you cannot sweep it up. It will simply disappear only to reappear later in the same area.
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    I went out there when I got home from work, and was able to sweep it really slow into long thin line, so now im wondering if its not algea, but it does back in the same spots...
    triptyx's Avatar
    Apr 2016
    1,438
    Perform an OCLT, that'll give you a good answer.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    Im getting the taylor test kit this weekend, but the HTC one im testing with now shows my reading for clorine over 10
