Thread: Use of heater while Ascorbic Acid still in the water
    Jun 2015
    Torrington, CT
    13
    ​Can I run the water through the heater while Ascorbic Acid is still in the water?
    JLeslie - 16x75 pool 38,00 gallons; Sta-rite system 3 modular media filter; electric heater
    JoyfulNoise's Avatar
    May 2015
    13,251
    Re: Use of heater while Ascorbic Acid still in the water
    Did you do the AA treatment with heater in the loop?
    Typically you do not want to run AA through a heater because it will etch the metal in the exchanger. If you have a heat pump with a titanium heat exchanger, then it's not a problem but a copper or cupronickel exchanger in a gas heater is not a good idea.
    Matt
    Jun 2015
    Torrington, CT
    13
    No, the water is not running through the heater. I have an electric heater - and a Sta-rite system 3 modular media filter. I just did the ascorbic acid for the second time because the first (12 pounds - for my 38,000 gallon pool) did not take out all the stains. But the water is too cloudy to see whether the stains are now out (I did it about 15 minutes ago). The PH is at 7.2, FC and TC 0, Alkilinity high at 180 and Total Hardness high at 250.
    Jun 2015
    Torrington, CT
    13
    on the test At what point can I start running the water through the heater? There is no FC but the total chlorine is between 1 and 3. I live in NW CT and usually swim all through May and June with the heater but I've lost May and 1/2 of June and am anxious to get it. The water temp is only 69.
