Results 1 to 7 of 7
Thread: unlevel pool????
    May 2016
    Anywhere, PA
    5
    unlevel pool????
    Hey everyone, new to the forum.
    I set up an intex 15 x 36 easy set pool. The ground was professionally leveled. The person that leveled, dug in as recommended. I would say at max height he dug in about 8-10 inches. I tamped the dirt down of the leveled area. I added foam board and a heavy duty tarp as recommended as I browsed through this forum.
    When I filled the pool it was less than an inch off the day I filled it (about 2.5 weeks ago). Pool looked great. Since I've filled it, we have gotten pounded with rain in the Philadelphia area. There has been washout under the foam and the pool is now roughly 2 inches off and there is a deep end.
    I'm very discouraged as you can imagine since I had it professionally leveled and followed the recommendations of most on this forum. I think the pool could be operable as it stands today even though it is now above the recommended limit.
    My concern is not the current state, but rather that we are only 2.5 weeks since filling and it moved that much. Meaning, it will only get worse and quickly especially if there is more rain. I'm not sure what I can do to prevent this. I know I will probably wind up emptying the pool shortly but don't want to run into the same issue again.
    My 3 year old daughter has been chomping at the bit to get in as I got the chemical levels correct. They are finally correct and ready for the weekend and I noticed this last night. I'm super bummed as you can imagine. Thanks in advance for all of your help.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: unlevel pool????
    Sorry about your situation. On my latest above ground I put pavers around the entire pool, seems to have prevented washout so far.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    May 2016
    Anywhere, PA
    5
    When you say around, do you mean under the foam or literally around the perimeter of the pool?
    Casey's Avatar
    SW PA
    10,448
    Welcome to TFP. Pictures would help a lot. Please fill out your signature and add all of your pool details.
    May 2016
    Anywhere, PA
    5
    Came home tonight and it was 3 inches now. Didn't want to risk it with the little ones and started draining. Once it's down and I start to relevel I will post pictures. I'm thinking crushed gravel after tamping and then foam and then tarp this time.
    Casey's Avatar
    SW PA
    10,448
    Crushed gravel will give you a good base to work with. You'll still want to use pavers under each leg. You made the right decision.
    May 2016
    Anywhere, PA
    5
    Quote Originally Posted by Casey View Post
    Sorry I might have not been clear, it is an easy set pool. There are no legs. I will upload some pics when I get home from work tonight from when I originally started. Pool is almost emptied. Going to let the area dry out for the rest of the day. Dig again tomorrow morning and get the gravel down and hopefully refilling by tomorrow night.
    Thanks again everyone for all of your responses.
