Thread: Pecan tree Pollen and white scale
    Does anyone have a solution for dealing with Pecan tree Pollen in their pool?
    I get on the walls at this time of year.
    Also I have noticed a white scale at the spillway from the spa to the pool it where the wind blown water hits the copping tile.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Pecan tree Pollen and white scale
    Welcome to TFP! Beautiful pool
    If you post a full set of results, we can help you figure out the scale issue. As for the pollen, try skimmer socks (or knee-high pantyhose).
    Please update your signature to include your pool info/specs....Go to User Control Panel, then Profile, then Edit Signature. You are allowed 5 lines of text.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Fiat and welcome
    Another 'yes' for the skimmer socks (skimmer screens). You will notice a huge difference.
    The AquaChem skimmer screens from Wallyworld are my fav
    I looked at your pool pic and it is beautiful 8)
    You're done SLAMing when:
    Quote Originally Posted by Fiat
    Ok I'm back as fiat-22 don't ask. So I think I figured out that it was mustard algae. Shocked it and added a algae killer.
    after 24 HR here are my readings
    FC=11
    CC=0
    TC=5
    PH=7.8
    T/A=155
    CH=32
    CYA=80
    TEMP=86
    Pool is 18000 gal. One question is should I run the waterfall pump? It look liked algae was growing in the strainer. Can algae grow in the piping?
    Here is pic of the scale. Any thoughts? After 36 hours the water is still a little cloudy
    Ok cleaned the filter added water as it was a little low. Readings after 36 Hr.
    FC=8.5
    CC=0
    TC=5
    PH=7.8
    T/A=130
    CH=32
    CYA=50
    TEMP=86
    Thanks for the help in advance
    Sam
    Yes, you should run the waterfall for at least an hour a day while your FC level is high. Algae can't really grow in the dark, but it can live in the pipes for quite some time and then reinfect the pool.
    I would bring the FC level back up to shock level. With CYA at 80, it takes quite a bit of chlorine to be sure you killed all the algae.
