Thread: Do I need to worry about CYA or pH in MD?
    Aug 2015
    Potomac, MD
    94
    In MD, the pool is open for only 3 months. Afterwards, more than 1/2 the water is drained.
    If I'm replacing the water every season, do I need to worry about CYA and pH? The reason I ask is that I have a bucket of Omega Chlor Sticks 99.3% Trichloro-s-triazinetrione (Tri-Chlor), which raises FC and CYA and lowers pH.
    I'm guessing that people use this in MD because water is being replaced every year?
    Grayson
    Outdoor concrete pool, 14,000 gallons, Purex Triton Clean & Clear Plus cartridge filter.
    Aug 2010
    Dallas, TX
    4,052
    Re: Do I need to worry about CYA in MD?
    Nope, use them.
    TFP isn't about throwing out stuff from the store, it's more about knowing the effects of what you use.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Yes, you do need to worry about PH, keep it between 7.2 and 7.8. I would use trichlor until the CYA gets to about 50 and then switch to bleach.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    If you're replacing that much water, I doubt CYA buildup will ever be a problem. Just keep tabs on the test results and if it gets too high and/or the tabs aren't dissolving fast enough to maintain the FC, supplement with bleach. Trichlor is very acidic, so watch the pH and TA. A little-known factoid about poolmath.... The last row labelled Suggested Goal Levels has a dropdown option for trichlor as a chlorine source. It will then autofill suggested levels for you.
    May 2016
    Aberdeen, MD
    60
    Re: Do I need to worry about CYA or pH in MD?
    3 months? Mine is already open
    13,000 Gallon AG Vinyl, Hayward Power-Flo Matrix 1HP Single Speed @ 80GPM, Hayward XStream 100SF Cartridge Filter
