Results 1 to 10 of 10
Thread: Not understanding my K-2006
    May 2009
    Tracy,California
    23
    Well I have read the manual but my still sorta lost on the Chlorine test....heres the part what does this mean....I do know about the 25ml or 10ml marks the the tube.
    Chlorine (Free, Combined) Test
    1. Rinse and fill large comparator tube to desired mark
    with water to be tested.
    NOTE: For 1 drop = 0.2 ppm, use 25 mL sample.?????????
    For 1 drop = 0.5 ppm, use 10 mL sample.????????????
    15k Midnight Blue StoneScape Pebble inground pool and spa
    Pentair clean and clear plus 420 filter 2 Sta-rite 1 1/2 hp pump Raypack 406 heater. TF-100 Test Kit
    Apr 2009
    Sarasota Florida
    143
    Re: Not understanding my K-2006
    Quote Originally Posted by MrDude
    fill the tube to either 10 or 25ml
    put in 2 scops of the powder and mix
    put in drops of the 0871 until the water goes from pink to clear. Make sure you keep count of the drops. Multiply the drops by either .2 if you used 25ml of water or .5 if u used 10ml. that is your free chlorine.
    Kidney shaped ~ 10000 gallon Ig Plaster pool with pool cage. 120sf Cartridge filter. Pentair WhisperFlo WFDS-26, 230 Volt, 7.8/3.0 Amp, 1-1/2 Horsepower 2 speed pump, Solar panels on the roof. Heliotrope HelioMatic 4000D solar controller.
    May 2009
    Tracy,California
    23
    Posted at 146...answered at 149...Nice !!!
    thanks
    Guest
    thanks
    Sorry it took so long... answers are usually posted much faster than that!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by waterbear
    thanks
    Sorry I was at Target. :P
    May 2009
    Tracy,California
    23
    Ok so here are my first results using k2006
    FC 1.4
    CC 0.6
    PH 7.4
    TA 110
    CYA 20-25 ...this one was very close to the top and a could barely see the black dot
    CH 250
    go easy on me...its my first pool
    Also did a check using my Aquachek handheld for comparison
    CL 0.0
    PH 7.3
    ALK144
    When doing the CYA test, if you fill it up all the way to the top and can still see the black dot, however slightly, the CYA level is very low and is normally written as zero.
    May 2009
    Tracy,California
    23
    Sorry my mistake...wrote down the wrong number it should of been around 20-25
    The next step is to get some chlorine in the pool. Since your CC level is slightly high, you should bring your FC level up a little high, perhaps 5 to 7 and then see if the CC level drops down quickly to some more reasonable level.
    You should also raise CYA up, probably raise it by 20 to somewhere around 40 to 50.
    TA and CH are fine for now.
    It would help if you could put the basic specs of your pool in your signature.
    May 2009
    Tracy,California
    23
    Thanks Jason I will add some bleach . Hope my specs help now.
