Thread: DB Powerline impeller removal
    May 2016
    Tulsa, OK
    1
    Any tricks to removing a stubborn impeller from this model Doughboy pump? It is recessed in the backplate assembly seen here http://doughboy-parts.com/powerline.htm
    I can't see how to get a strapwrench around it.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: DB Powerline impeller removal
    Welcome to TFP
    It may be a while before people with knowledge on this pump see your post, not many doughboy pumps out there...
    Stick around and enjoy the site
