Thread: DIY shade arbor thoughts?
    Oct 2015
    DFW, TX
    176
    We're going to need plenty of shade and while umbrellas in the deck will work I was thinking of constructing an arbor on the back side of the pool as well as behind the retaining/seating walls around our 2 main seating areas. I've included a picture of our layout and excavation just started today but I was thinking I might be able to break it up into 4-5 sections of 12' rafters and still be able to roughly follow the contours of the walls/beam. I'm wanting to avoid additional posts on the pool deck areas along the sides and that's obviously not an option along the back but I'm thinking I could still make the arbor extend about 3-4' by cantilevering on just single posts or could extend the depth to 5-6' if I did a set of posts about 3' apart if I wanted to go deeper. I'll provide a sketch of my thoughts tomorrow but was hoping to get some examples/thoughts from the folks here. I was hoping to have some concrete footers poured as part of the decking and then just use the Simpson deck ties to hold the uprights instead of having to bury the posts and set them in concrete, etc..
    http://
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: DIY shade arbor thoughts?
    Not sure if you have looked at the shade sails, they are really nice
    Shade Sails LLC Innovative Tensioned Fabric Canopies Since 1997
    Feb 2015
    Santa Cruz, CA
    366
    We did an aluminum pergola - it was pretty easy to build and I did all of the work myself once the posts were set by my concrete contractor. Using footers and anchors is another recommended way - we just put the metal posts into our retaining wall.
    Here is a photo of what I built...
    2015 Build Link: 15'x30' Rectangle (3'-6", 5', 4' depth) 14,000 Gallon Pool, Finish: Wet Edge Primera Stone Black Kona. TF-100 Test Kit, Dolphin DX5+S Robot, Jandy CL460 Filter, VS 2HP pump, AquaPure 1400 SWG, iAqualink2, Automatic Safety Cover. No Heater
    We have one of these. Depending on how you place it, you can pivot the canopy and get a huge amount of shade:
    http://www.patioliving.com/treasure-...rella-exakz13/
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
