Results 1 to 7 of 7
Thread: How crucial is a second return? Could you live with a single return?
    MitchRyan912's Avatar
    Jul 2015
    Madison, WI
    338
    I only have one return, and that's how this pool has been since day 1. I've heard others say things along the lines of "I couldn't live without a single return in my pool," so I was wondering how indispensable having multiple returns are to your pool?
    If multiple returns are absolutely necessary to you, what do you do with them to improve circulation?
    2016 total pool rebuild thread: here. Pool: 26,000 gal IG vinyl liner (20'x40') in Madison, WI. Gear: ​Superflo VS, Triton TR-60 filter, 2" hi-flow MPV, & Raypak 266A heater. Testing: Taylor K-2006C. Manual chems: 12.5% NaClO liquid, granular CYA, baking soda, 31.25% muriatic acid.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: How crucial is a second return? Could you live with a single return?
    How does one return work in your pool now? Do you get effective skimming? Have dead spots where leaves and junk hang out?
    The idea of pool returns is to set them all pointing the same direction create a circular water flow to move debris to the skimmer(s). Usually, either clockwise or counterclockwise will work better depending on wind direction and other factors.
    Jul 2015
    Madison, WI
    338
    It was more of a general question, to see if some are OK with a single return or not. I can only have plumbing on one side of the pool for the foreseeable future. Too much concrete to dig up.
    Aug 2010
    Dallas, TX
    4,052
    All of my returns are all at one end of the pool. So yes, I have four returns, but it's like having one really wide return. Could you easily install two returns (or more) just all on the same wall?
    It has worked pretty well that way since '57...
    May 2016
    Troy IL
    476
    The pool at my house only has one return jet. I kind of hate the way it's set up, but honestly it works really well. I have one skimmer, and one return jet. They are both overhanging the top edge of my pool into the water, and within 6 inches of each other. The jet points the opposite direction of the mouth of the skimmer so as to push all the water around into it's mouth. It works fine, even if I was skeptical and still hate it. But it makes winterizing fairly easy and I guess I can't complain.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    Mar 2013
    CT
    351
    I only have one return in my 21,000 gallon in ground. In the shallow end. I'm sure two would be better but I get along fine w just one. Maybe I would get better skimming action w two but I don't see that having just one causes any issues...
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    30,431
    pump running what is your clean psi? 20+?
