Results 1 to 7 of 7
Thread: Warning about fiberglass filters!
    Apr 2016
    Rockville MD
    43
    I'm sure somebody has experienced this already, but I might as well repeat it here. Because of clearance problems, the old Tagelus sand filter had to be moved a few inches to make room for a valve that I had to install. So I moved the filter by giving it a big bear hug and walking it inch by inch to its new location. No, I didn't drain it first. It was a minor struggle but no big deal.
    Within minutes I started itching like crazy. Obviously the 15 year old tank shell was shedding tiny bits of fiberglass, and the irritation is much worse than touching fiberglass insulation. My arms and legs are still sore and inflamed.
    Moral of the story: Use a towel or something to protect your body parts if you need to handle an old fiberglass filter in any way.
    20x35 in-ground oval. Wet Edge Luna Quartz finish. Hayes Super Pump with AO Smith V-Green 165 VS motor. Polaris 380. Enersol solar heating with automatic controller. Automated chlorination with Stenner pump.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Warning about fiberglass filters!
    Been there, done that. Long sleeves and work gloves to open it.
    Once burned is twice learned.
    30,402
    Good post, Poolray.
    That doesn't come up often and it's a good reminder.
    MitchRyan912's Avatar
    Jul 2015
    Madison, WI
    327
    I spent a good chunk of last summer itching.
    2016 total pool rebuild thread: here. Pool: 26,000 gal IG vinyl liner (20'x40') in Madison, WI. Gear: ​Superflo VS, Triton TR-60 filter, 2" hi-flow MPV, & Raypak 266A heater. Testing: Taylor K-2006C. Manual chems: 12.5% NaClO liquid, granular CYA, baking soda, 31.25% muriatic acid.
    Aug 2010
    Dallas, TX
    4,052
    Great, now I have a Great White song in my head.
    38,239
    Isn't there something like applying hair spray first to help prevent that? I would not want it in my clothes/towels either.
    Aug 2015
    Folsom Prison, CA
    124
    That happens to me and I hate it! I wonder what would happen if it was sprayed with rubberized undercoating or bedliner or something??
    Jeff || 19,000g IGP || SwimClear 3025 Cartridge Filter || Hayward TriStar 1.39 THP pump || K-2006 Test Kit || 80% Surface Coverage Heliocol || Hayward Controller || Hayward Phoenix 4X4 || "Solar Rings" || PoolSkim
