Results 1 to 10 of 10
Thread: Pool light went out while draining pool
    Apr 2016
    Philadelphia, PA
    73
    Draining my pool right now to fix CYA levels, and just when the water level got below the light, the light went out. Won't turn back on. Think there is something that actually requires water contact or something like that going on or just a coincidence and now I need a new light, too?
    38,475
    Re: Pool light went out while draining pool
    They require water for cooling. You likely blew the bulb from overheating.
    Yup. Fixture is flooded to stay cool. Never turn on your light unless its submerged. At least now you get to learn how to replace the bulb.
    37,000 gal IG concrete free-form, Hayward TriStar VS pump, Sta-Rite System 3 cartridge filter, Polaris w/ booster pump, CircuPool RJ60g SWG, Hayward OnCommand w/ remote
    Jun 2014
    15,221
    And can clean-out that light niche behind it since those inevitably become trouble spots for algae anyways.
    38,475
    Quote Originally Posted by mattttt25 View Post
    The fixture is not flooded, the niche is. Water should not get into the fixture where the bulb is located. It should only get between the niche and fixture.
    Aug 2010
    Dallas, TX
    4,052
    Note what lights say on the right side of my old light.
    Apr 2016
    Philadelphia, PA
    73
    Yea, sucks. I got the light out while the pool was drained below the light. Luckily (depending how you look at it) there was only one screw holding it in up top. Not looking forward to dipping my hand in cold water putting it back in though
    Aug 2010
    Dallas, TX
    4,052
    That's pretty common, my new light is only held on by one screw.
    38,475
    Fyi, when you replace the bulb, you should also replace the gasket seal.
    Apr 2016
    Philadelphia, PA
    73
    Yup I have the glass and gasket in my car, thanks.
