Thread: Ring on my spa
    May 2016
    Naperville Illinois
    2
    Ring on my spa
    There is a greasy film around my spa I'm new to this and don't know if it's normal or not. Also I've only had the tub for a month and it seems like it's dirty I.E stuff floating in the water that's kinda yellow/brown hope I can get some answers
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Ring on my spa
    What is the CH? Raising CH to 130-150 will help with foaming. Usually if you eliminate foaming the oils won't gather at the top of the tub as much. If it still does you can get a Scum-ball to soak it up.
    Here is how I maintain my tub. Has worked great for 3 years or so.
    How do I use Chlorine in my Spa (or pool)?
