Thread: Underground Leak:
    Jun 2007
    NC
    255
    Underground Leak:
    Well, I lost 3/4" of water in the pool yesterday and there was not a party
    Tonight I start the bucket test to determine if it's:
    a) the main drain (YUK!),
    b) the 2 returns under 8' of stamped concrete, or
    c) the sheer descent that's in the coping under 8' of stamped concrete
    My bet is that it's the main drain due to wet block joints in the retaining wall about 5' down from the top . I'll know after checking for 24 hours with the pump running in each scenario, then 24 hours with the pump off/pressure off.
    In the meantime I may have to look at getting the scuba tank hydro-stat'd and trying to squeeze into the wetsuit and doing thorough exams of the bottom then some dye testing...
    Any other ideas?
    Triad Region of NC
    18x37 Vinyl IG (24,000 gal.), BBB & GoldLine AquaLogic PS4 SWG, Hayward 1 HP Superpump / Hayward Sand Filter / Polaris 280 cleaner / 6 deck jets / Sheer Descent Waterfall (in coping) / Brick Red Concrete Coping / Stamped Concrete Deck
    Lots of oak trees, maple trees, *and* leaves!
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Underground Leak:
    You've ruled out leaks at the equipment and through your waste line?
    Jun 2007
    NC
    255
    Quote Originally Posted by spishex
    Unfortunately I haven't seen any water leaking from the waste line.
    Last night I had it set to pull from just the skimmer and return to just the waterfall. It'll decrease the TA some, but it will rule out 1 scenario. I can re-balance the pool when I'm not loosing water.
    Tonight I fill back up, set it so it pulls from the skimmer and returns through the 2 returns only.
    Then do the same thing with the main drain...1st thru waterfall, then returns, noting results in each scenario.
    Any way to "cover" or seal off the main drains at the liner/bottom of the pool so the hydraulic pressure of the water itself won't leak, if that's where the leak is?
    Triad Region of NC
