Thread: Opened the pool a few days ago, What levels should I do for SLAMing?
    Hello All,
    Pool was a swamp. Vacuumed as much junk off the bottom as I could and scrubbed. Next morning it was already blue instead of green. I had put about 5.5 or so gallons of chlorine in. This was Monday evening.
    Pool currently looks blue but cloudy. I'm wondering what I should get my levels to, to SLAM. In my notes from previous year I have written down 60 CYA is about 24 FC to shock, I just cant find the little graph I got that from.
    Here are my results, I'm going to run out there and put a little chlorine in and lower the PH. Wondering what I should do for CYA/FC after that. Going to go grab a bunch of salt so I can get the SWG going too. thanks for any suggestions
    FC - .5
    CC - .5-1
    PH - 8.2+
    Salt - 1960ppm
    TA - 40
    CH - 60
    CYA - 20
    Aaron
    26' Octagon, IG Pool, ~16gal, 5-5 1/2' deep, Liner, Sand Filter, Polaris Autoclear salt system, 3/4hp Pump, Pool Blaster Max Vacuum, TF-100 Test Kit.
    Re: Opened the pool a few days ago, What levels should I do for SLAMing?
    Actually, I just retested FC/CC with a fresh sample and better lighting... It appears that
    FC - 0
    CC - 0
    I believe the testing chemicals i'm using are from last season (stored inside). So I'm not sure. I'll try to level a few things and retest in a little bit.
    Aaron
    Aug 2014
    Northern IL
    4,615
    Get the pH to 7.2-7.4. Is this the graph you were looking for? Pool School - Chlorine / CYA Chart
    Last year's chemicals should be fine if stored indoors.
    Quote Originally Posted by MarianParoo View Post
    Yes thats it! thank you. I just put some chlorine and acid in so I'll retest in a little bit.
    Aaron
    Aug 2014
    Northern IL
    4,615
    Good deal. Don't go crazy with the chlorine until you get that pH down. Do you remember how to SLAM your pool? Pool School - SLAM - Shock Level And Maintain
