Thread: Cya agent question
    May 2015
    pittsburgh pa
    62
    Cya agent question
    First off pool is marvelously clear, numbers are good and slam complete.
    When i tested in April had
    CYA 60 so slammed at that number 24 fc
    May 6th completed slam with 0 overnight chlorine loss.
    PH 8
    TA 100
    So i added some muriatic acid to which brought me to
    PH 7.4
    TA 80-90
    Now we've had a good deal of rain in Pittsburgh, and i did have to pump out about 4 inches of water. Tested CYA today plenty of sun and I'm coming up with 30, almost to point of the dot not disappearing.
    Is it possible that the agent is bad, or has my CYA really dropped 30, which i wouldnt complain about. I could cut down my chlorine usage, but i dont want my pool to turn green.
    11,000 gal (21' round) AG
    DE EC40
    38,284
    Re: Cya agent question
    It is pretty rare for that specific regent to go bad. But, it should not drop 50% without replacing 50% of the water.
    So, I really have not explanation.
    FYI, you will actually loose more FC ppm to the sun at lower CYA ... so you may find you are actually adding more bleach while trying to maintain a lower FC level.
    May 2015
    pittsburgh pa
    62
    should i use some pucks to bring it up?
    DE EC40
    38,284
    That is one option or add stabilizer separately.
    30,419
    It will take quite a few pucks to raise it to a suggested 40 but if you have some around, that's fine to do it. I usually like to see folks add the powder and save the pucks for vacation but both work.
    Nice work on your pool! You're a TFP'r for sure.
    May 2015
    pittsburgh pa
    62
    Thanks Dave,I truly take that compliment.
    My wife's like there he goes with his blue box
    This site is the best time I spend on the net! So many knowledgeable people willing to help is extraordinary today!
    DE EC40
