Results 1 to 16 of 16
Thread: Basic test kit, numbers.
    May 2016
    Corcoran, CA
    27
    So i bought a Walmart test kit until i can get the tf-100. I also picked up some 10% liquid bleach on sale for 2.50 per.
    It doesn't give me FC/TC, just chlorine/bromine level? I measured my pool today and here are the numbers.
    CL= .5-1
    pH=7.5
    CH=240
    CYA=30
    TA=33
    I know I need to add the chlorine, but I believe the rest of the numbers are within a decent range.
    ALSO, the water is getting green, do I need to SLAM it?
    New owner of old pool
    30K GAL, IG plaster, max-e-pro xf 1.5hp motor with 3/4hp booster,
    Triton FNS Plus 60 D.E. filter, sweeper out of commission, built 8-1989
    38,251
    Re: Basic test kit, numbers.
    The chlorine level is too low for your CYA level .. and if it is turning green, you need to SLAM. Although you can not do that without the FAS-DPD chlorine test.
    Aug 2014
    Northern IL
    4,615
    You can throw a jug of bleach in there. When does your kit arrive? Do you have muriatic acid (MA) on hand? If not, pick up a gallon for future use.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    What he said ^^^
    To save some future grief and buying a lot of extra bleach in the future, you can try to maintain 12 FC every day by using poolmath. Take your reading, plug it into poolmath as the Now and use 12 for Target. That'll keep it from getting worse. It might even clear things, but you can't consider the SLAMfinished until you've gotten accurate measurements with the FAS-DPD chlorine test. This is just a stopgap procedure so your pool doesn't turn into lime jello while you're waiting for the TF100.
    May 2016
    Corcoran, CA
    27
    So, add the chlorine. Then when I get that test, SLAM? This is the test I bought.
    http://www.amazon.com/Arch-Chemical-...6+way+test+kit
    I should have the tf100 around the 1st. Just had to shell out 500 for deductible on insurance. That hurt.
    38,251
    You could assume your FC is 1ppm.
    Use PoolMath to target 12ppm (your shock level for CYA of 30ppm)
    Add that amount of bleach.
    Add 1 bottle of bleach daily after that until your FAS-DPD test kit arrives.
    Aug 2014
    Northern IL
    4,615
    If you didn't order the TF100, then for now, order a FAS-DPD kit. What you want is the K-1515C.
    May 2016
    Corcoran, CA
    27
    Will do! I bought 10 gallons of 10% bleach. Hope I can stretch it out. Also, just bought this:
    http://www.maytronicsus.com/resident...eluxe/deluxe-4
    Aug 2014
    Northern IL
    4,615
    Lots of cross-posting. If the TF100 is on order, no need to get the 1515.
    May 2016
    Corcoran, CA
    27
    Sorry, I'm just new and feel like its getting out of hand. The tf100 is on back order, and I hope to get mine by the 3rd with the holiday.
    38,251
    Back order? who did you order from?
    May 2016
    Corcoran, CA
    27
    Amazon. I have prime, so free 2 day shipping.
    38,251
    The TF-100 is not sold on Amazon ... only tftestkits.net or poolsupplyworld.com
    May 2016
    Corcoran, CA
    27
    Ahhhhh! Ordered while tired. It was the tf2006. I canceled order though, since back ordered and all. Will jump on tftestkits later and order the correct kit. Thanks.
    38,251
    PSW would be quicker, they are in CA ... TFtestkits is in NC.
    The K-2006 is fine, just a little short on some reagents.
    May 2016
    Corcoran, CA
    27
    Thanks again, cheers to a non green pool!
