Thread: Pool is all balanced but salt levels are dropping
    Apr 2015
    Nashville
    40
    What can this be? What am I missing? I had cleaned the internals of the SWG it was ok at 3200-3400 but it dropped like 200 last few days. Am I missing something? Chlorine levels and clacium and CYA are around optimal.
    16 x 32 (3, 5, 11)
    23-24,000 volume
    Liner Pool
    Aug 2010
    Dallas, TX
    4,052
    Re: Pool is all balanced but salt levels are dropping
    200 is probably within the error ratio of your tests.
    That said, there is only one thing that will cause a quick drop in salt levels - water replacement. So, have you had heavy rains that have caused you to need to drain, or do you have an auto-fill? Or heavy backwashing?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    I'm curious. Is the 3200 from the SWG or from some test strips?
    And in either case, how old is it?
