Results 1 to 11 of 11
Thread: Hose Creating Foamy Water?
    Hi TFP,
    I posted this earlier but I'm out of ideas and feeling very frustrated and I'm hoping for some advice.
    I'm getting foam when my water is agitated. My CYA was high so I drained half the water and refilled and got it back down to manageable levels. But the foam remained. I opened the pool May 1 so any algaecide should have dissipated by now. My chemicals are good, CL 5, PH 7.6, CYA 60. The water is very clear. Yet the foam problem remains. So I was cleaning off my table and noticed that when I first turned on my garden hose, I see foam. This was the same hose I used to fill the pool. This is a new hose. I read an article that some garden hoses leach chemicals. Could this be the problem?!?!?! If it is, the only solution would be to drain the entire pool and refill it with fresh water? I am out of ideas and want the water to be safe as my kids swim in it and summer is well on it's way. Please help.
    Robert
    Gunite. 14,869 Gallons. Hayward cartridge filter. Hayward Super Pump 1HP. Chlorine.
    Baltimore, MD
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    Re: Hose Creating Foamy Water?
    I'll let the true experts work out other possibilities, and I have no clue on the hose, but have you checked your CH? I have a vinyl pool so rarely worry, but if it gets too low I see some foaming. Sometimes mysteriously, other times from known causes like a grandson with an electric bubble machine. Obviously the bubbles would be expected to foam, but is much worse if my CH was way low. However, it's when WAY low, like under 70, when I noticed any difference.
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    Jan 2012
    'burbs of Augusta, Georgia
    7,345
    You don't mention your calcium level? How are you testing and which kit?
    Can you please give us the most current:
    FC
    CC
    pH
    TA
    Ch
    CYA
    Thanks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    You didn't happen to accidentally grab some splashless bleach by mistake, did you? From what I read here, it's almost as good as Mister Bubble.
    Low CH will also cause foaming. I would have never believed it until one of our rare rainstorms refilled my spa for me. And it didn't just bubble, it foamed. Until it got diluted with my high CH pool water.
    Hoses will leach chemicals. Anyone who's ever drank from a cheap garden hose as a kid will attest to that. And there;s a reason they sell special water hoses for RVs. But I don't think they foam, just taste awful.
    Taylor T50 Kit.
    FC 5
    CC ? <-- I ran out of 087 powder
    pH 7.6
    TA 180 (I know this is high but I'm going to have it retested at store. I get new testing reagents every year but I want to make sure my ones for TA are ok).
    Ch 300
    CYA 50-60
    The only other thing I can think of is algae but algaecide was added.
    Baltimore, MD
    sorry, repeated post.
    Baltimore, MD
    Jan 2012
    7,345
    Algaecide might be the problem
    Do you mean algae? As in I have it in there despite the algaecide?
    Baltimore, MD
    Jan 2012
    7,345
    yes, some algaecides can cause foaming or cloudy water. The cure to most of these problems if more bleach.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,492
    CH of 300 eliminates that as the foam source, generally CH above 130-150 eliminates foaming. I think I would SLAM the pool for a few days and see what happens.
    Is there a way to perform a SLAM without a FAS-DPD kit?
    Baltimore, MD
