Results 1 to 11 of 11
Thread: Pool is open, pump is running and I've got first reading....
    Jun 2013
    Green Bay, WI
    72
    TA = 110
    CYA = 30-35
    CH = 140
    Ph = 7.2
    Chlorine = 0
    What do I need to do first?!
    Doughboy 24' x 48" (AG), AQUA Tools Cartridge Filter, Frog System
    2004 Sundance Cameo SPA
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Pool is open, pump is running and I've got first reading....
    Pour some bleach in the water to get chlorine in there.
    You say CYA = 30 - 35 and we always round up to the next number for chlorine purposes, so your CYA is 40.
    You want to target 5ppm, but NEVER go below 3ppm of FC.
    Support the site
    Aug 2014
    Northern IL
    4,615
    How does the water look?
    Jun 2013
    Green Bay, WI
    72
    Quote Originally Posted by MarianParoo View Post
    Green. Looks like algae on bottom.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by willie1280 View Post
    In that case... vacuum first and sneak up on the stuff so it gets sucked away before it can scatter. If successful, clean the filter. Then proceed. If unsuccessful with the vacuum, proceed anyway with the SLAM
    Aug 2014
    Northern IL
    4,615
    Bummer. Is the frog system still connected?
    Have you ever performed a SLAM? If not, read this: Pool School - SLAM - Shock Level And Maintain
    May 2014
    Franklin, NC
    9,184
    Should have noted that detail
    SLAM is the solution
    Support the site
    Jun 2013
    Green Bay, WI
    72
    CL = 1
    TA = 120
    PH = 7.2
    CH = 120
    FC = 2
    CC = 0
    TC = 2
    Water looks good minus a tad of cloudiness.
    What do I need to do next?
    May 2014
    Franklin, NC
    9,184
    You need to conduct a full SLAM
    Support the site
    Aug 2014
    Northern IL
    4,615
    Did you add any CYA?
    Jun 2013
    Green Bay, WI
    72
    I'm SLAM'ing right now...loss 7 on the chlorine overnight.
